Rob Erdos
I'm currently populating the firewall of my -6 project with hardware, in eager anticipation of hanging the engine (TMXIO-320 with AFP FM-150 fuel injector). I plan to install my Vans GAS-5 gascolator on the lower-right firewall. I know... a gascolator isn't required or recommended for a fuel injected system, but the regs in Canada say otherwise, so I need one. (Oh, and just to avoid distraction, I know that some people put them in the wing roots, but I'm trying to avoid the duplication of something I'm not sure I need anyway.)
Confused! My FWF plans for the RV-7 (Dwg OP 28) show a gascolator installation on the firewall, backed up by a complicated-looking VA-161 Gascolator Bracket. Sources of confusion:
1. It appears that we can't use the VA-161 Gascolator Bracket shown on the RV-7 plans, as the RV-6 has a different firewall (extra doublers on the back of the firewall in an X-pattern). What sort of doubler or reinforcing plate is used to mount the gascolator on a -6?
2. Once it's installed, how is it accessed? Do we typically drill a hole in the lower cowl to take fuel samples? *
3. Further, despite Transport Canada's insistence on the issue, I see no reference to a gascolator in the Installation Manual from AFP for the FM-150 F/I System. Is there any problem installing one? Can I be confident that a gascolator can take the outlet pressure of the high-pressure fuel pump?
Your collective wisdom much appreciated,
Rob Erdos
Ottawa
Rob Erdos
Ottawa
