WingsOnWheels
Just a heads up for RV-6/6A builders. As part of the FWF kits Vans sells, they have "FF-6/6A ADDITIONS" for $60. The additions are the RV-7 center tunnel cover and heater baffle plus the RV-7/9 drawings for plumbing routing.
If you have a newer fuselage kit these parts were already included in the fuselage kit. If you are far enough along to buy the FWF kit, you have probably already found a solution for the fuel/ventline routing. If you have an older kit, this would be ideal to order if you want the RV-7 tunnel and plumbing layout, but I would buy it while working on the fuselage before you mount the engine.
Just wanted to to you a heads up so you don't have to ship that bulky tunnel cover back to Vans.
