RV...Phorrrr
I'm New Here
Well, what a day Ive had!! 3.5 hours to remove the tailwheel/spring assembly from my 4!
I have an older style tailwheel spring (the bent one with the lock nut 1" from the ground) and want to upgrade to a screaming eagle one with a new spring. The nut holding the spring retaining bolt into the fuz tube would freely rotate but wouldnt undo so i had to drill the thing out, 2 hours later the nut dropped off and the bolt comes out then the tail spring is seized into the tube, I was glad to get home!!!
What do you guys think of the screaming eagle unit?
Cheers
Paul
Cheers
Paul
