Just completing the firewall and I see that the inner and outer pivots for the pedals are on different axes - ie, misaligned by 9/16", with teh outer pivot point further forward. I have looked hard, studied the arrangement, thought about it, and cannot see what benefit there is - though there is plenty of friction and will be extra wear in time. I note that Tom Martin added an extra bracket to the inboard pivot - which I think is just visible in one of Ax-O's photos. I am inclined to make this modification, but also to modify the outer pivot so that the outer one is aligned with the inner one - seems a much more satisfactory solution to me unless someone can see a problem or tell what what the advantage is of the arrangement per plans??
Chris
Chris
