RV-4 Rudder Mounting Distance
RVFan671
References to drawings are from the USB plans.
Looking at the drawing for 7A (Rudder) and 30 (Emp & tailwheel attach) I don't see reference to how far the heim joints should be from the rudder to mount to the vert stab (at least to start with). I have been doing some work on the tail so replaced all hardware. The upper two bolts that go through the stinger mount and vert stab in section C-C of drawing 30 call for AN4-6A but I used AN4-7A when I replaced them because not enough threads were showing (I think they even had the thin washers).
I now have the tail of the AN4-7A hitting the bottom fiberglass faring on the rudder before I hit the stops. I'd like to validate the distance the rudder should be from the vert stab before I go back to seeing if I need to use a low profile nut on a 6A bolt or washers on the bolt head of the 7A.
I checked the USB RV4 plans - they do show the 4-6A bolts holding the tailwheel stinger weldment to the rear spar bulkhead with the bolt facing backwards (nut behind vert stab spar).
Later model plans (6/7/8/9) have these bolts installed facing forward (with nut inside fuselage) so they don't interfere with rudder.
Try that.
No joy
Try that.
Tried and couldn't get the bolt in facing fwd. There is a triangulation piece off the stinger that prevents a washer from getting flush against the stinger. Solution was a -6 bolt with a thin washer and low profile nut.
