RV-4 Parts, components, and equipment
HDDavis
Member
1 Bendix PS-5C Pressure Carburator (aerobatic) overhauled and yellow tagged??$500.00
1 Skytech Super Flyweight Starter model 122-12HT?..$250
(The starter is only strong enough for a 0-235. It did not turn my 0-320 fast enough. It was only used 50 hours and is about 15 years old. Will not turn 0-360 fast enough either)
1 Delco 60 Amp Alternator?$125
1 Comant C1215V VOR/G5 Antenna (new)?..$200
1 AVT-4 Antenna Specialist Blade Antenna 15??.$125
1 Complete Nav/Com-Transponder System. Includes AT50A transponder, Com 11A transceiver, Narco 126 switching panel with marker beacon, Nav 12 with glide slope, URR-3 slide slope receiver, Nav 12 marker beacon receiver, AR-500 encoder- pre-wired and ready to install??$1750.00
1 Sensenich Propeller M74DM, Pitch 60, Minimum thickness at stations 7 and 11???.$900
1 SPA-400 Sigtronics Intercom ? NEW??$150
1 Westac 3AQ3 Quad AHT/EGT/CAT/EGT- NEW??.$100
1 King 8002 Loran??.$50
Truck load of RV-4 Parts
Includes Conical engine mount, 2 control sticks and torque tube, flap control, elevator trim cable, stabilizer root fairing- NEW, horizontal stabilizer, vertical stabilizer, 1 aileron.
New parts: F427 skin, Z F412 bulkheads, 1 F415B floor rib, 1 F415A floor rib, 1 T403L rib, 2 T404R ribs, 1 T404L rib, 1 W409R rib, 2 W409L ribs.
Used front and rear seat backs.
I will not separate or pack and ship. Must be picked up in Danville,VA
All for $500
