I aquired an R4 fuselage with empenage. I'm looking for wings and other parts you may have.
I don't have any parts for you, but I'm close by if you have any RV4 build questions..if you have a fuselage that's already built, be advised the spar carry through section , if installed, is matched to a wing kit. If you find wings, the spar carry through bulkhead and splice plates should be with the wing kit. Mix and match RV4 centersections can be done, but that may require drilling up some new splice plates and frame parts.I aquired an R4 fuselage with empenage. I'm looking for wings and other parts you may have.
I have a canopy for sale listed here https://vansairforce.net/threads/rv4-canopy.226437/#post-1774059I aquired an R4 fuselage with empenage. I'm looking for wings and other parts you may have.
I may be interested in the panel. My biggest issue is getting it through a DAR or registedered since it has a data plate on it an no bill of sale from the last registered owner. Any suggestions?I have a canopy for sale listed here https://vansairforce.net/threads/rv4-canopy.226437/#post-1774059
Also these two items listed here https://vansairforce.net/threads/fs-throttle-quadrant-gascolator.227598/#post-1776819
Not posted for sale yet but I have an RV4 instrument panel blank and a Van's fuel valve as well
You have a can of worms that needs sorted out before you spend too much money. You would need alot of miracles to prove 51 percent as builder, and a VANs build number should have been transfered to you. If it's a transfer registration, you'd be doing a repair...has this been a flown aircraft ?I may be interested in the panel. My biggest issue is getting it through a DAR or registedered since it has a data plate on it an no bill of sale from the last registered owner. Any suggestions?
My RV4 kit (I built mine) as well as all the others I have been involved in are delivered from VANs with the holes in the fuselage center spar carry through bulkhead match drilled to the spar and spar splice plates, that is why the wing kit contains fuselage bulkhead components . My, and other RV4 fuselage kits did not come with those component. The build sequence for RV4s make mention in the plans to order and build the wing prior to the fuselage for this reason. I have been involved with mating a new wing to an existing and flying aircraft and it often requires rework of the center section for the aforementioned parts.To the best of my knowledge the RV-3 and RV-4 kits were not pre-punched or matched hole. Therefore your concern regarding matching the wings to the main Spar Center section in the fuselage is not valid.
You are correct. I will now delete my erroneous replyMy RV4 kit (I built mine) as well as all the others I have been involved in are delivered from VANs with the holes in the fuselage center spar carry through bulkhead match drilled to the spar and spar splice plates, that is why the wing kit contains fuselage bulkhead components . My, and other RV4 fuselage kits did not come with those component. The build sequence for RV4s make mention in the plans to order and build the wing prior to the fuselage for this reason. I have been involved with mating a new wing to an existing and flying aircraft and it often requires rework of the center section for the aforementioned parts.
I also have Older Style:
- gear leg fairings
- wheel pants
- cowl with cheeks
I have the same issue with my six. But I was able to find two sets of wings with the center section and the splice plates. I'll give you a call once I get to the center section on my 6. Currently I'm just trying to figure out if I have a salvagable 4 on my hands.My RV4 kit (I built mine) as well as all the others I have been involved in are delivered from VANs with the holes in the fuselage center spar carry through bulkhead match drilled to the spar and spar splice plates, that is why the wing kit contains fuselage bulkhead components . My, and other RV4 fuselage kits did not come with those component. The build sequence for RV4s make mention in the plans to order and build the wing prior to the fuselage for this reason. I have been involved with mating a new wing to an existing and flying aircraft and it often requires rework of the center section for the aforementioned parts.
