Tomas J
Active Member
If you use to fly X-plane flight simulator and like to try my RV-4, you are welcome to download it from here ...
The machine is under construction, both in reality and in X-plane. I have taken picture of the real panel and put it into X-plane. As you can see there is still work to do on the panel - but it is good enough to fly in X-plane.
Just unzip the file and install the folder to your X-plane library. Then you select the "Tomas RV-4" and "SE-TOJ" and you can take off... but to get the horizon corrrect you need to go to "Settings>Rendering Options>Lateral field of view" and change the value to 052.00
If you don't have X-plane, you can download a demo from www.x-plane.com and fly for five minutes before you lose your stick.
As I have to lay my time on the real RV-4, I will be happy if someone like to go on with this RV-4. It need to be painted... and how knows, If I like the way you paint it, I might make the real one the same.
If you try it - please let me know what you think... can it be to any help for the real flying...
Approach to Innsbruck in my RV-4 wich have not yet left the garage...
![xplane_rv4.jpg](/proxy.php?image=http%3A%2F%2Fdl.dropbox.com%2Fu%2F3745995%2FWAF%2Fxplane_rv4.jpg&hash=512013f02894a156fbac8822347d5234)
