RV-4 cowling p.n.
n700jl
Can some one provide me with the part number for the RV-4 upper and lower cowling? Thanks in advance.:)
RV-4 cowl
Probably the best way to get the correct part number is to call Van's. Don't forget you will also need the left and right cowl cheeks.
RV4 Cowl pn
When you call, you will get a kit part number. The kit has upper and lower cowl halves, inlet ramps, oil door, cheek extensions, side cowl hinges but I don't think it give you the hinge for the firewall to cowl. You will need to order them.
Richard
