FlyinTiger
Going through my "new to me" RV-4 built in 1994, it was made clear to me that I should replace the plastic brake lines at least up to the firewall with aluminum tubing. As the brakes heat up on those down hill taxi ways the plastic lines can soften from the heat, allowing brake fluid past the line and saturating the brake pads while letting air into the system. Unfortunately this happened to me on the right side the second time I taxied out to the runway.
Biggest challenge on this project? Getting the gear fairings off...they probably haven't been off in quite a while and the pins were pretty well set in place. I sprayed parts of the piano hinge I could get to with silicon lubricant, twisted the wire to work it in and then proceeded to work out the pins. One side was much more stubborn than the other.
Thanks to Ed Martinson for the help getting a list of parts so I could get this right without several trips to the local parts store.
![](/proxy.php?image=http%3A%2F%2Fi1314.photobucket.com%2Falbums%2Ft571%2Falberthibpshman%2FIMG_2088_zpsa9907797.jpg&hash=4e5656ebcc407f850a00e47757fb573e)
![](/proxy.php?image=http%3A%2F%2Fi1314.photobucket.com%2Falbums%2Ft571%2Falberthibpshman%2FIMG_8460_zps4b2bda7d.jpg&hash=39d50f1b34c8c02ad0754fe9c1e189cc)
![](/proxy.php?image=http%3A%2F%2Fi1314.photobucket.com%2Falbums%2Ft571%2Falberthibpshman%2FIMG_2085_zps318b10e9.jpg&hash=025a3d98e1c7ed528a1224ab78ccb654)
