I have recently completed the Emergency Maneuver Training program with Rich Stowell, which included Spins, Rolls, Loops, Hammerheads, and Immelmans (among other things). The 6 days of training was in a Decathlon, 180 hp CS prop.
I strapped on my parachute and took my -4 (160 hp, Hartzell CS) up yesterday to perform the maneuvers required to remove the "Aerobatics Prohibited" placard (flight permit received from Transport Canada). For any who are anticipating a transitioning from a Decathlon to a -4, here was my experience:
- Full aileron deflection results in two lateral "bumps" on the stick. I understand this is not unusual for RV's and so it did not surprise me. Some kind of aerodynamic oddity - maybe someone out there can explain why RVs do this.
- A one-turn spin in my -4 only needs 1/8 or so of a turn to recover (after the final control input of forward elevator). This compares to a half turn required in the Decathlon.
Note - if you plan to spin your airplane, be aware one RV-4 may not recover the same as another, or at all. Testing by professionals has shown that minor differences on the same airplane can have dramatic effects. Approach this area with great care.
- The hammerhead was interesting – I fell out of the vertical portion to the left a couple times before getting the discipline to put in enough right rudder to keep going straight up. Takes quite a bit more right rudder than the Decathlon.
- On the first couple of loops I pulled 4 g’s before taming the next ones down to Rich's recommended 3.5. I suspect the control force required on the -4 is a little less than the Decathlon.
- I am having one issue with the aileron roll – when I have completed the roll my g-meter is reading +3, which is too much. I am also gaining a little altitude. I monitored my initial pullup, max at +2, so I suspect I am inadvertently pulling during the final 90*.
- Absolutely no issues keeping the speed under control during any of the maneuvers. My CS prop undoubtedly assists greatly with this, but I still need to remain vigilant with respect to speed and ensure recovery all the way to level flight is done with authority.
- All of this needs much more practice, which I will enjoy doing.
