I haven't been folowing all the threads too closely, so only just saw this one. I have been flying competition aerobatics in my RV-4 for just over 12 months now. It has an O-360-A1A with FP wood prop and Ellison TBI. Empty weight is about 950lb @18%MAC, I fly with 40litres of fuel or less, and I'm ~87kg. I have made no aerodynamic modifications. Just recently I flew Intermediate in the NSW State Championships and finished 5th. The RV-4 is capable of Intermediate level, but you need to stay ahead of the aircraft and keep the speed in check. It isn't the easiest aerobat about, due to the low drag, slow roll rate, stability and roll/yaw coupling. Flown smoothly you can get around the sequence with +5.6/-3.5g. I flick both ways, to the left is cleaner, but I don't flick above 80KIAS and half power. The spins are uneventful, you only need to do a 1.5 turn spin maximum usually. Rather than dive into the box at Mach 1 or better like most, I drive in level with about 20"MAP (~140kias) and start, then try and fly smooth and tight keeping the speed in control on the downlines. As soon as the nose goes below the horizon, the throttle is at idle, the only time I use full power is when vertical up, otherwise ~20" is enough. If speed gets above 150KIAS the roll rate diminishes and the ailerons get heavy, and you use too much of the box. 120-130kias is nice. The slow roll rate coupled with rapid speed increase means that rolls on downlines are the most hazardous figures. I always wear a parachute and started out above maintaining above 3000ft AGL, now I'm down to a 1500ft limit.
Get some good instruction before you start, which is hard as the -4 will be above aerobatic gross with two people on board. You need an instructor who knows RVs or at least is used to low drag aircarft, the Pitts is great, but completely different to an RV to aerobat. Practise wingovers, loops and barrel rolls (in that order) to get used to rate of speed buildup, and used to recovering from a nose-low attitude. Leave a constant power set and try and recover at the same speed and altitude as you began. If you 'dump the nose' and the speed gets away, set power idle, roll wings level and pull firmly to the horizon monitoring the 'g'. I'm ex-military and was used to clean, fast accelerating aircraft, the nearest thing to an RV-4 that I have flown otherwise was a Macchi MB326 trainer. If you aren't comfortable with flying your RV this way, start very cautiosly, or simply don't do it. I'm looking for a G-200 to compete in now, I don't want to break the RV, it's too good a general purpose sport aircraft. Structurally I have found no problems, my airfield is a bit rough and that seems to cause most of my maintenance hassles. An RV can romp through basic thru Sportsman sequences, using only half the fuel a Pitts will. If you want to compete seriously in aerobatics above that, then you should be building something else.
If anyone else out there is competing in an RV, I'd like to chat and swap notes. If anyone disagrees with what I am doing, let me know, and why.
see the Australian Intermediate Known at
http://www.aerobaticsaustralia.com.au/dloads/Sequences/2005-06/2005 06 Intermediate FormC.pdf .
