Thanks Dave! I'll check & see. It doesn't have to be the exact outline. Just for EFIS/Switches/Breakers layout. I'll trace the original to make sure the former outline is exact.
That's because there are no two of them alike...same with the 4/6 as well. The only way to get an accurate dxf/dwg drawing is to use your existing panel and scan it with a CNC or something to get an accutate plot (we often do that for these airplanes when customers desire us to cut a panel blank for them). If you use someone elses outline, it may be "close", but I'll almost guarantee it won't match exactly. Those were/are a builder fabricated item, and as such each on ends up being unique. If you send me a paper tracing we can scan that with our CNC as well....
