I weighed my recently acquired 1992-era RV-3A and decided that I needed to be at not more than 8 gallons to make the 1050 pound limit for fun flying. So I calibrated a 1/4 inch wood dowel as a dip stick for my nominal 24 gallon fuselage tank one gallon at a time. It was in doing it that I discovered the tubular inset or can build into the fuel tank behind the panel obviously intended to accomodate a "long" instrument in the lower middle of the panel. I don't have a long instrument in the panel now so had no idea it was there. Wonder if its a common feature of 3 and 3A fuel tanks or is it unique to this bird?
Anyway, I drained the tank, inserted the stick diagonally from the fill port to the bottom of the tank, and added one gallon at a time. Due to the can, the 1 gallon increment spacings are not what you might expect in the affected range. Recorded the measurements and made a backup stick as well.
Its very resurring now to know before and after each flight exactly how much fuel I have and used, for weight and fuel burn calculations.
