I must admit, one of the things that I have not been looking forward to on the RV-3 project has been installing the engine control cables at the quadrant end. This is mostly because of how tough the job proved to be on the RV-8 back when I built the Valkyrie ? there isn?t enough room, penetrating the gear towers was a pain, and the quadrant mount was sandwiched in an awkward place. I figured that with the tiny RV-3, things would be even worse. But low and behold, I was able to take a look at our ?stalking horse?, another local RV-3 project that is being helped along by an experienced F-1 builder (ok, he is THE F-1 builder?), and I noticed that instead of using the bulky cables with large mounting nuts on each end, he used the Aircraft Spruce A-920 series cables ? much more compact, and easily fit in the close confines of the -3. To secure the ends of the outer casings, they use a notch/slot arrangement which necessitates building a special bracket, but this proved amazingly simple with some extra angle and a little fabrication. The pictures below are fairly self-explanatory. The lack of bulk in the cables allows them to be placed as close together as the levers in the DJM quadrant, so everything comes out parallel ? very nice!
Cables installed on the quadrant ? it is easier to put the ends on the quadrant levers, then attach the cables.
Fabricate the cable support with some angel, drill three holes, then band-saw the slots to the holes.
I used a pair of AN3 bolts to attach the cable support ?comb? to the F-303 forward bulkhead ? very sturdy!
Overall, I am pressed with the smooth operation of these cables, as well as their ease of installation. Oh, and they don?t come with a label that says ?Not for use on aircraft??.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Paul
Paul
