pekuba1610
Member
Back again with center section questions.
Does anybody remember from which piece of AA 3/4 x 3/4 .063 6061 T6 you made the seat rib attach angles (also can't find a F- number) which are to be riveted flush to the aft-spar center section?
I searched for hours in my inventory PDF and the packing lists but all I can find in 3/4x3/4 are the W- angles (root-rib attach W-334 etc.) and the AA6-063x3/4x3/4 12 feet or 6 feet long.
I do not dare to cut the two 3 1/2 " pieces for the seat rib attach angles from one of these long pieces. With a quick look at the fuselage longerons I couldn't spot the length needed in the end for the longerons.
Does anybody remember from which stock you fabricated the seat rib attach angles?
Peter
Peter
