Andy Hill
We have just finished fitting / drilling the Rear Spar for the RV-3.
Rear Spars, particularly the setting of sweep and incidence, cause much stress to RV builders, with limited room to keep ED and get the wings set correctly - as urged by Vans after the earlier RV-3 issues.
Some RV-3B builders even suggest using an oversize (hence overweight
) spar to keep minimise the issues - given the lack of matched holes etc., it would seem a good idea e.g.
We approached this from the other direction:
Do not use the rear spar supplied by Vans! It leaves no room for error when you drill the wing attachment hole. After mounting the wing and drilling the hole I realized the hole violated the edge distance requirements by 1/16". It doesnt sound like much, but at least one RV-3 pilot has died as a result of rear spar failure. I recommend replacing it with a 2" wide piece. It only costs about 40 bucks, you will be glad you did.
- We made the fuselage "slots" for the rear spar
- We clamped the rear spar into the fuselage to set the rear / front spar distance as measured from the wings, during fuselage construction
- We drilled the wings for the rear spar bolts as per plans i.e. with good ED
- Drilled one end of the rear spar for the bolt - again "in the middle" so no ED issues
- Fitted the wings, and trimmed the rear spar length so the wings could establish the correct sweep, then drew a line on the rear spar where the other hole should go
- Drilled this hole centered vertically in the spar.
- Lightly clamp the rear spar to the fuselage and adjust laterally until wings square, and vertically for correct incidence.
- With undersize holes drilled in the rear spar, match drill into the fuselage bulkhead
- Final Drill holes through rear spar fuselage
- (After priming, will rivet Rear Spar into fuselage) This should not be an issue - there is good access to set these rivets.
