jim miller
My RV3 was repainted before I got it and I am putting on the N-numbers
and ID plates that came with the airframe. There are two metal plates around 2 by 3 inches. One has only Make. Model, Serial #, and engine
model that goes on the rear under the horizonal. The other is slightly
larger and also has builder name/info. Where should this one go. It looks
like it may have been mounted on turtle deck just behind the box type
roll bar. This surface is curved and the already drilled holes don't fit the
new plate. Could it go on the back of the roll/bar box?
Also I have two large experimental decals about 18 inches long with 2 inch
letters. I would like to use only one if possible and where should I place it.
Jim Miller
Jim Miller
