johnbrooker
Member
I am just finishing the baffling (0320) on the RV3.Thinking about where to mount the oil cooler,I have looked at a few builders sites and not seen a picture of a oil cooler.If anybody has pictures or information how and where you located it,also what size cooler you used.A friend and I have a RV4 will 6 row mounted on the motor mount with scat hose to it,hole in baffling is covered by a plate with a 1 inch hole in it.We have a small swinging door using a screw and platenut that can be adjusted to cover that hole.the door is now covering 1/2 of the 1 in hole.Oil temp is still low unless running WOT,I am assuming the 3's run cool also.Any info would be helpful. RV3BFB (fast back)
