DIMPLE, DIMPLE, DIMPLE
22 years of sheet metal work does provide a tiny secret, just as said in the above post. Be very careful...but here it is. Dimple your hole just like any other. Now, use a hand held Dogleg Deburr Tool with the proper sized piloted countersink bit...VERY gently touch countersink the hole...3 LIGHT turns works well. This will remove about .002" or less of material from the hole and the rivet "thinks" it has a nice machined nest to sit in, but you have the strength of the dimpled hole and it looks a little nicer. DO NOT try to "re-machine" the dimpled hole to look like a normal countersink in a .040" or thicker material. Too much and you will reduce the thickness of the dimpled material and reduced tension strength of your sheet metal. "What about the outer alclad protection you just removed from the dimpled hole?" For most of us, the airplane skin will outlive us builders. For those near salty areas, you can use an alodine touch pen on each hole. I believe the act of the process will make some feel better in the long run
. Try it with a piece of .025" and squeeze a few rivets. Now try some .032", hint hint...you can be a bit more liberal with .032 and achieve and nicer hole and a better finished outcome. Use a flat edge and a flashlight to compare your art work.
For the newer builder...Please stick with dimpling, we love our RV friends and other airplane friends. Seriously, please stay with dimpling with anything .032 and under. Yes, some say .032" can be machined, but it is too easy to over machine and knife edge the bottom of the hole. The materials we work with is too thin to "fix" with the next size larger diameter of rivet. In most cases, the strength of a dimpled hole is much stronger.
Copied from another source:
"This is a design guidebook of material strengths and fastener strengths that is approved by the Army, Navy, Air Force and the FAA.
Shear strength of 3/32 MS20426AD flush rivets (values are ultimate strength in lbs.) Sheet thickness
Dimpled Countersunk
0.032 217 178
0.040 217 193
0.063 217 216
This shows a 18% loss of strength for every countersunk rivet in 0.032, and an 11% loss in 0.040 material. The Handbook also had a warning that in 0.032 material, this was a "knife edge condition" and was undesirable,
and not approved."
