No one can build an entire avionics harness for an airplane ? it just can?t be done! Of course, no one can build an airplane either - it is an absurd proposition that anyone could build something so complex! But you CAN build a lot of airplane parts, and then assemble them into an airplane?.and in the same fashion, you can build wiring harness components for a number of different boxes, eventually joining them together to find yourself with a working panel!
Such are the thoughts one has as they haul out the tools, wires and connector kits to begin building the central nervous system of an EFIS-equipped, IFR machine. Our dual-screen G3X system will be joined by a GNS 430W, SL40, GTX330, and GMA 240 audio panel ? not to mention the Tru Trak GX Pilot and ADI. Almost all of these boxes have to talk to one another in some way, shape, or fashion; understanding how they are going to do this takes a lot of study, sketching, and note-taking. We?ve had the boxes here now for several months, and the manuals before that ? but I am just now reaching the point where it is time to take tools in hand and start building components.
I have been doing my own avionics installations for literally decades ? under the supervision of A&P?s and Avionics techs when I had certified machines, and working closely with the companies that provide today?s experimental EFIS?s when I moved in to the homebuilding world. My RV8 was my first real foray into all-digital equipment, and the panel went together quite well with the harness furnished with the units, plus those I built for the rest of the avionics. When we rebuilt the panel on Louise?s RV-6 we likewise started with Steinair harnesses for the EFIS and autopilots, plus the older radio harnesses for the equipment being re-used. Joining the bits and pieces together was lots of fun, but it did take time to get it right.
For the RV-3 project, we are doing the harness work from the ground up. Partly, this is because harnesses are just now becoming available for the G3X line, and partly it is more interesting to do it myself and share the experience with everyone else. There is no better way to understand how your system works than to build it yourself! With installation manuals for all the equipment, lots of conversations with Stein (and the gang) in Minneapolis, and some integrated drawings from the Garmin guys, it is doable ? with the right tools and an organized approach. Garmin technical standards are very high, and this forces one to work to a higher level of precision and quality. Nothing wrong with that approach! Besides, it?s a good excuse to buy better and more expensive crimping, stripping, and cutting tools?.![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I will try to update this thread as the harness work progresses but to get started, tonight?s project was building the ?stubs? for the PFD and MFD ? the two G3X display units. When you first look at the connectors for these units, it is easy to panic and run screaming in to the night ? they have 50 pin D-Subs! Fortunately, only a very few of the pins are actually used. Power, Ground, Signal Ground, and Lighting are all very straightforward. Add to that the CAN bus (two wires), a jumper on the PFD to tell it that it is the PFD and a four-wire EEPROM module that stores the configuration for the PFD ? and that?s it! The data lines use shielded twisted pairs, so knowing how to properly terminate the shields to a ground wire using heat-shrink solder rings is important to make a neat and electronically sound assembly.
Probably the toughest part of getting started on the harness was figuring out the lengths of wire to leave on each ?pigtail? as I got going. Since the fuselage is an open book right now, I used a small piece of parachute cord to simulate the harness components and give me an idea how much wire to leave for each part of the system to give me room to play with yet not waste wire. I hate having to stop in the middle of a job to wait for more wire to arrive from Stein! We?ll see how well I do in a few more days of work?. Fortunately , there are really only three (major) components to the G3X system ? the two displays and the GSU (ADAHRS and Engine Monitor in a box). The magnetometer is a peripheral to the GSU that only takes a few more conductors ? not a big issue. So now that I have the two display connectors done, I only have the GSU to go! Of course it is way more complex, with two big connectors. Then there is the avionics stack of course. Looks I?ve got some fun shop time coming up?.
A couple of pictures:
Not many of the 50 positions on this D-Sub are actually used for the Display units ? thank heaven! There is some moderately advanced splicing and shield work involved to do it up right.
The high quality connectors have tapped #8 holes for attaching ground straps ? nice and convenient!
Two down, and I don?t want to count how many more to go?.
Here is a link to a few more captioned pictures:
http://picasaweb.google.com/Ironflight/2011_01_26RV3AvionicsHarnessConstruction#
Paul
Paul
