RV3 LSA
My original plan for an RV3 was to use an 0200 engine I have. I just wanted the proven flight characteristics, not speed. Vans said the plane was designed for Lycoming . The mount, the cowl etc would be a problem and they had no information that would encourage the approach.
So I ended up with a 3B and 0320 engine and moved forward even though I have the experience and equipment to deal with the challenge. Regarding simply running the engine slower, installing a restrictor plate in the carb or whatever, consider this. I have not flown a -3, but the angle of attack might be undesirably high at 138 MPH with thrust limited to that speed.
I do plan to build an RV1 LSA. 0200 engine,RV3B wing and (undecided) tube and fabric fuse with flying wires in the tail for "nostalgia. I think the angle of attack issue could be addressed with higher incidence built in the wing attachment. How much incidence....good question.
