There WILL be a taildragger RV14 option. I believe the beta tester is doing the prototype of it now.
If they don't follow through, I'll be selling my wings.
(once she gets over the "horror" of putting a footprint on the seat cushion she will have no problem).
I ordered my -14 emp/tailcone as a tail dragger. I may start with it as a tri-gear until I get comfortable in it and then convert it to a tail wheel later. But I wanted to build in the tail wheel receptacle now so it's ready for later.
I did not know you can convert from a tail dragger to tri-gear once you started building one or the other. So I guess the main gear are in exactly the same position for a tail dragger and also the tri-gear planes?
I'm pretty keen on this new one,although I have to get my 6 finished first, thing is I haven't seen a pic of a taildragger 14, not even a drawing, it would be a shame if they decided against it, any one got info on it?.
Matty
Would somebody puhleeeese make a photoshop photo of an RV-14 that just happens to be a taildragger, in flight on on the ground or anything to quench our collective imaginations please? I may or may not be able to do that where I'm at, certainly not on work hours
giggity....
Would somebody puhleeeese make a photoshop photo of an RV-14 that just happens to be a taildragger, in flight on on the ground or anything to quench our collective imaginations please? I may or may not be able to do that where I'm at, certainly not on work hoursIE- take a finished in flight photo and work some magic....
giggity....
