Hello All,
Has anyone encountered a blocked fuel vent line in a QB tank? I was going through Section 18 on my tanks ensuring all work was done to plans and completing any unfinished items. Page 18-06 says to "double check that the vent line is clear and has not become blocked with sealant." The left tank was fine. I could easily blow through the external fitting. The right tank seems to be completely blocked. I can neither blow nor suck any air through the fitting. Now what? A possible solution to me is blowing compressed air through the fitting in an attempt to remove the blockage which I assume is tank sealant. Not sure that would even work since cured sealant is pretty sticky, tough stuff. But in keeping with the "First, Do No Harm" mantra, I wanted to see if anyone else had any thoughts or has encountered this issue. Frustrated this wasn't caught by Van's first.
I appreciate everyone's time.
