RV-14 Bird Strike at 800'
Mike Meehan
Friend
This comes from the Flights Above the Pacific Northwest (FATPNW) Facebook group. Not sure how to link to it.
Ouch that's gotta hurt, the bird more-so. Eagles are usually smart enough to avoid airplanes...usually.
Wow, that really buckled everything in that outer section beyond the fuel tank and ahead of the spar. But as far as I can see, that's all that's damaged... Would it be as simple as drilling out the rivets to get that leading edge off, building up a new one, and then riveting the new one on? Or does the leading edge overlap with the skins aft at all?
I hope you're right
I came pretty close to tagging one head-on over the James River about a year ago, at maybe 2000 feet (higher than I would have expected).
There are a LOT more eagles in Virginia than there used to be, even a few years ago. Great news until one decides to dogfight you. :)
This is when it pays to have a plane built from proper materials, Nother better than metal👍:)
