N402RH
Here is a picture of the Advanced IFR RV-14 panel. We will have versions of this panel for both VFR and IFR using either the AF-5600 or Skyview EFIS. The hole in the top of the center section is for Van's canopy jettison handle. The holes on the right and left of the panel are for the Alternate Air and Cabin heat.
The panel has two AF-5600T Touch screens, Remote Light-Weight Mode S ES Transponder, ADS-B, remote PS-Engineering Audio Panel with IntelliVox®, AF-COM Radio, Advanced Autopilot Controller, Wig-Wag Lighting, Flap Positioning, Two-Axis Auto-Trim, Avidyne IFD-540 GPS Navigator and an optional XM Radio-Weather Module.
Since the panel uses our Advanced Control Module, installation will be incredibly easy for the builder -saving many hours of frustrating work. Not only does the Module make it easier to install, it's much easier to maintain and upgrade in the future.
Pricing will be very attractive since we not only build the panel but we also manufacture most of the equipment.
Rob Hickman
Advanced Flight Systems Inc.
N402RH RV-10
![15779516183_acbb8e234a_h.jpg](/proxy.php?image=https%3A%2F%2Ffarm9.staticflickr.com%2F8634%2F15779516183_acbb8e234a_h.jpg&hash=0ae0e79b621d9e1887e8a45cb4abaadf)
Rob Hickman
N402RH RV-10
