The 914 is 115 Hpand can be ordered ready for a CS prop. It does not have FI and is a bit pricy. Power isn't that much higher at (IIRC) 115Hp, but it will keep that power to high altitudes. So, your IAS won't be that much higher, but TAS will go up with altitude.I've just been pondering what if the 914 Turbo went into an RV12? With Variable prop? Anyone got any thoughts? I think Americans cannot do it but Australians can. I wonder what speed and performance improvement it would provide.
Any comments welcomed.
Jim.
Is this classified as a constant speed propeller? that's the question !
Jim.
Good plan. Our setup on the 912S only develops ~4800, maybe 5000 in climb. Being able to pitch the prop for 5300 to 5500 would help the TO and climb performance a lot.I am planning to fitting a std 912S keeping it easy to fit just as vans, but with a cockpit adjustable Variable pitch prop, that will give me the extra bite during take off from 5500ft ASL and extra pitch during cruise at altitudes 8000+ ft.
Vans appears to be already struggling with overheating of the 912S. A 914 is likely to make the problems so much worse, I'd have thought.
Do you know if he is using the Waterless Coolant ?
If so, trust me he has to use the 50-50 Water Glycol based Coolant; To comply with the EASA coolant AD I did a lot of cooling testing on other installations to switch back to the 50-50 from the Waterless and install the higher pressure rad cap; That latter coolant will move your Coolant and CHT temperatures up by at least 40 F on the same installation...Not Good at all; OK, it may fix the false problem (not a problem if the installation is properly designed) of local boiling but shifts the problem to lower engine life and in a few cases I have seen, engine seizure ! Another thing with the Waterless Coolant, your Oil Temperatures will very likely exceed the limits, they are already high anyway. The 50-50 will keep them about 20 F lower than with the Waterless Coolant.
You will need a coolant gauge with a red line at 120 C (248 F), but trust me it will pat off; ROTAX was also working on a higher capacity Rad within the same original Rad dimensions; I tried it with some improvements but by far the 50-50 Glycol is the winner (about 8 times the delta Temp).
In the US, it's not "constant speed" that's not allowed for light-sport. It's "cockpit adjustable".
