Geico266
At OSH the judges pointed out that the nylock nut supplied by Rotax to secure the throttle cable bolt is not compliant with accepted standards for aircraft. Any nut firewall forward is to be all metal. While (of course) we are suppose to follow the plans to be in compliance with E-LSA it should be noted to make sure you are also complying with the accepted standards for US aircraft. Yes, we are experimental, but trust me, the judges were not impressed with my explanation.
Also, Rotax now recommends an idle stop on the cable to avoid deforming the stops at the carb by pulling on the throttle too hard. The newer engine kits seem to have them, but the older -12 kits did not.
