Geico266
There is nothing in the instructions / plans that tells us how to hook up the tach lead from the engine. There is a wire coming from the ignition / charging area on the back of the engine that has black shielding and a plug. Is this the tach wire?
There are two wires coming from the fire wall forward harness that has pins that fit, but which pin / wires goes into which hole?
