After a few hard landings, then check them ! ! ! ! ! !![]()
Are these shims what you are looking for??
http://www.vansaircraft.com/cgi-bin...90-320-144&browse=airframe&product=axle-shims
Larry- If you have a little bit (say 1/2 degree) of toe in, you probably won't have any handling issue. What you REALLY DON'T WANT is toe out- (front of wheels wider than aft)- this will result in a truely ugly handling airplane! SteveYep! I just wonder how much or little we need to shim.
I would say it about 1/2 degree toe in. I guess I'll leave it alone and see how it handles on taxi and landings.
Thanks Steve!
Since I did that yesterday, I'll jump in. I balanced the wheels and packed the main bearings and installed them. I put a sweeping bend in them, and they went in fairly well then. Was almost surprised myself, but it worked quite well.
John Bender
Okay John....what's a "sweeping" bend....and did you do from the top down? I also turned my nut till the bearings wouldn't move....is that what you did...sure sounds draggy.
Are you guys trying to say the hole is horizontal ? I put my axles on so the holes are vertical. I then put the pin down thru. Needs to be bent a fair amount until it will go in.
John Bender
Pete,I also turned my nut till the bearings wouldn't move....is that what you did...sure sounds draggy.
