OK, I am anxious, when does a guy get his serial number assigned? I asked Vans but got no answer.
OK thanks, that would make far better sense then. I guess I will have to wait another month for mine.
Yes, if you register as E-LSA, Van's will assign serial number 120461 to your aircraft. If you register as E-AB, I believe that you can use any serial number that you want as long as it is unique (not used for the same make and model).I am "Customer 120461".
Don't that look suspiciously like serial number 461 is assigned to me?
Hrm, that's interesting Since I bought the empennage kit from someone else I got his customer number 120170... which I think ends up being Larry Geiger's RV12s... great...
Larry, if you see this, can you confirm your customer number? did you get your wings from Jetrep and got his customer number first and VANs is double assigning the customer number?
WOO!
Larry's RV-12 is serial number 120171
Joe
okay, cool... In your post to sell your -12, you have it listed at 120170...
http://www.vansairforce.com/community/showthread.php?t=67083
Glad that is cleared up!
--Brian
