Rv-12 Plans
Bartsey
Member
While I have found a few errors on the plans, like the handholds being mis-marked, the plans are very good. (sometimes you have to really read slowly and use a magnification glass to count rivet holes). One shortcoming is on page 18-02 where the dimensions for the actuation brackets and the pivot brackets are found. You'd think the drawings would be to the correct size so you could use them as templates, but instead, the drawings are just a tad off scale. My technique was to take the plans to Staples and have them adjust the plans exactly to scale on their reproduction machine. The guy scanned the plans and was able to adjust them by measuring their size on his readout of the scanned plans. Now I have templates I can use for at least the actuation brackets.
Some scissors and rubber cement and away we go.
Bart
