richardsmi
Member
I have a new un-flown RV12 in the UK.
The Dynon is giving Zero oil pressure even though we know the Rotax has actually got oil pressure.
The Honeywell sensor has failed and I think that it has caused a problem in the VA/ fuse/ panel to the left of the cockpit.
Checking the red wire which feeds the oil pressure sensor there should be a 12volt supply.
All the earth/ground connections are zero resistance to each other ie battery terminal, Dynon case and engine block.
ther is a 12volt supply out of the Dynon and into the AV
Has any one got a circuit diagram for the AV unit.
Or better still has anyone had a similar experience and overcome it?
I want to get flying!
