I chose N123M. Not the best, but it is only 5 syllables.
Actually 123M is 4 syllables. If you include N123M, it becomes 7.
How do you finalize your reserved N number? Do I write it in on the Aircraft Registration Application (8050-1)?
In fact, Light Sport 123M tells the informed controller a whole lot more. He knows your gross weight, your stall speed, your cruise speed, and he probably has a pretty good idea about how much cross wind that you can handle, without cluttering up his runway with a bunch of debris! So, I guess 6 syllables might be more accurate.
