RV-12 Glide test data
yankee-flyer
GW about 1200 pounds
Engine at Idle power
Density Altitude 3500 MSL
Two pilots, each flew one set
Pretty bumpy so a fair amount of scatter in the data
Eyeball "best fit" curve through data points.
Flaperons UP
KIAS Rate of Descent, ft/min
85 980
80 945
75 855
70 760
65 670
60 575
One notch flaps (results as expected!)
80 1080
75 1015
70 910
65 750
Will do best range (feet lost in one mile) soon.
Current thoughts if fan quits
Push Over NOW
FLAPS UP
Establish 60-65 knots while using 45 deg banked turn to desired heading
Probably establish 80-85 KIAS to extnd glide distance if necessary (TBD)
DISCLAIMER: Neither pilot has any pretensions of flight test training and there was a fair amount of data scatter. Draw your own conclusions or conduct your own tests.
Wayne 120241/143 WM
Originally revision 0 of the POH gave the Maximum gliding distance airspeed as 85 kts. Now it is 63 kts.
Quote below from
RV-12 PILOT OPERATING HANDBOOK
Revision:2 Date:08/12/13 Page 6-10
FORCED LANDING (Complete Power Failure)
Maximum gliding distance airspeed ? 63 kts
Minimum rate of descent airspeed- 55 kts
Joe Gores
Changed again in the 04/03/2014 POH: Page 6-12, max distance 63 kts, min sink 59 kts. Puts the two speeds real close together ...
Wayne 120241/143 WM
You already have that data (at least for one weight), but you will want to re-do it on a smooth day, with more data at the low airspeed end.
Procedure: plot VS (vertically) vs airspeed (horizontally). Draw a smooth curve thru the data points. Lay a straight edge on the horizontal axis; pivot around the origin, rotate the straight edge up counterclockwise until it just touches the curve. That point is best glide, no wind, at the weight the data was taken.
Hey Tom! Where did you get the April 2014 POH update?? All I can find is the 12/11/2013 update.
Another Tom
POH RV-1207/02/14
RV-12 revision page
POH RV-12 07/02/14
"Curve" is a bit different than expected. I will also make a log on my next flight.
POH Update
Thanks for the wake-up call. I figured out that I was not seeing the current info on Van's site. Chalk it up to old cookies!! Once I did a "refresh on the page, I could see all of the changes. I am posting this, just in case someone else goes down this road.
Tom
Thanks for pointing out the update
Looks like my limited flight test data and conclusions weren't too far off what the pros got.
THANKS
Wayne
Graph
I forgot, at these relatively low indicated airspeeds you probably need to make the correction to calibrated airspeed (this will most likely move the low speed points to the left).
