Geico266
Over the past month I have received several calls from -12 builders asking how I filled the pulled rivets on my -12 before painting. I thought I would make a thread for this subject. Actually, I thought I already did, but I can't find it. ![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I filled the pulled rivets 4 years ago before painting. None of them have "fallen out" like a few thought they would. I can assure you having worked with Superfil they are not going to fall out.![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
This is paint prep and has nothing to do with LSA.
Here we go....
1. You will need to order a small size Superfil from Aircraft Spruce ( or another distributor) Yes, they still make it. You can make your own using micro balloons and resin, but Superfil is much more consistent. http://www.aircraftspruce.com/catalog/cmpages/superfil.php
2. Go to a farm store / animal medical supply house and buy a bag of 1" x 16 gage hypodermic needles and a matching number of 20ML syringes. They are pretty cheap.
3. Stop at the local bottle shop and grab a 12er pack of your favorite warm beverage, and send to the OP as a gift for this tip of the day. Buy warm so you won't be tempted to drink my beer.![Roll eyes :rolleyes: :rolleyes:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
4. Sand or grind the point off the needle and deburr it. You don't need to hurt yourself.![Eek! :eek: :eek:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
5. Start on the bottom of the wing or stabilator so you can refine your technique. Mix 2-3 table spoons of Superfil and put it in the syringe. popsickle sticks work great. Working time is about 30 mins, throw it out and repeat.
6. Start with a line of rivets and place the modified needle into the bottom of the hole and fill from the bottom up. Notice the 16 gage needle fits inside the rivet hole, smart huh?![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
The mixture continually comes out (like a caulking gun) so you need to judge filling time and when to move to the next rivet. Leave a little of the mixture "proud" or higher than the rivet head. Allow it to cure for 1-3 days. Don't try and smooth it down, that comes later. Move in one continuous motion stopping only to fill the hole for a second or two. Wifey or kids can help with this project!
7. After 1-2 days, take a 90 degree die grinder with air pressure set at 40 psi and a 2" OLD worn fine sanding disc. (Both available at Harbor Freight) What you are going to do is "shine" the top of the rivet. Do not remove metal, just shine the top. The excess Superfil will be gone in an instant. The top of the rivet becomes your guild. If only have gets shined you are not holding the die grinder straight. If you look at your pulled rivets closely there is a burr where the mandrel pulled out. This eliminated that burr also. Wear a dust mask, that's an order.
The extra time it took was about 40 hours, and after doing the math it added 1.3 oz to the plane.
If you want the look of solid rivets this is the way to go.
Have fun! Hope this helps.
Here we go....
