RV-12 ELT antenna
JRo
I just finished Ops checking my 406 ELT. Fortunately I had my electronics specialist buddy on hand. After successfully testing the ELT, and entering the due dates for ALL 3 batteries (ELT, audio alerter & Remote control) both on the devices and in the Aircraft Maintenance Record, we went to re-stow the ELT.
My ET buddy 'bout had a fit when he saw how Vans instructed us to stow that co-ax antennae cable! Co-ax cables have a specified minimum bend radius. They should be gently "looped" to stow. Vans has us "kinking" them again and again to be tightly tie wrapped to the ELT in a small bundle. I've been assured by Jerry that, if stowed as instructed, rather than gently looped, it is only a matter of time and heat exposure before the cable will fail.
Who knew!?
Jim R.
N448JR
RG-58A/U - the one with the multi-strand center core - is usually listed as a 2 inch minimum bend radius.
RG-400 - to the Mil Spec - is listed as a 1 inch minimum bend radius.
How tight do the RV-12 instruction want the bend radius?
ELT Antenna cable routing
The bend radius is more than 1":
Plans:
Tony
Who knew!?
Jim R.
N448JR
Show your buddy this data sheet....:)
http://www.wellshow.com/spec/cable/Harbour-RG400.pdf
Plans:
Tony
Actually, the KAI drawings for the ACK 406 Mh ELT (the one currently suppied in the avionics kit) do show a much tighter bend radius. The one shown in these now obsolete drawings was the Artex. The error will be corrected in a future revision.
Aside from Gils chart, the common rule of thumb for coax minimum bend radius is 5 - 6 X the diam of the coax (depending on which coax it is).
RG-58 and RG-400 are essentially the same diameter and yet they have a 2:1 difference in bend radius.
...and that is why "common rules of thumb" are not very useful...:rolleyes:
Look up the specific data, it's much better than a rule of thumb...:)
Well, I actually did look it up a while back (though I no longer remember where), and the chart I looked at put RG-400 at 5X the diam., and RG-58U at 6X, so I am not just winging it Gil...
But it does just go to show you that on the internet you can find a lot of information that is not correct. Yea, unfortunately even here on VA (though I can assure you I am not the only one providing it ;))
Maybe, but "charts" on the internet can be just the same as "rules of thumb"...:rolleyes:
In this case it's actually quite easy to get real data from the cable manufacturers, and that real data rarely (ever?) quotes bend radius as a multiple of diameter.
RG58A/U straight from Belden -
http://www.belden.com/techdatas/english/8219.pdf
2 inch minimum radius - just over 10x the diameter.
RG400 from another manufacturer/supplier with numbers taken from the M17/128-RG400 Mil Spec.
http://www.farnell.com/datasheets/1714215.pdf
1 inch minimum bend radius - just over 5x the diameter.
Don't use table/charts and rules of thumb, go for real data from the suppliers...:)
I'm sure the engineers at Vans work that way.
