Hello Builders,
I am new to your forum and will be certifying the first E-LSA in the states this month to a builder in Northern California. I also happen to be an FAA Inspector so don?t let that bother anyone.
I got my first look at the aircraft this past week and was nicely surprised with the kit and workmanship. I copied all the builder manuals and documents he received from Van?s and discovered the Conformity Statement 8130?15 form was incorrect and had the wrong ASTM standards called out on it. The correct form is in FAA Order 8130.2 figure 4-30 on page 244-3 for E-LSA aircraft. Figure 4-20 on g page 244-2 is for Special LSA aircraft two different standards.
I contacted the Light Sport branch AFS-640 and Van?s and pointed out the mistake. Sure enough Van?s agreed with me and will be sending new Conformity Statements to all the builders of E-LSA aircraft from Kits.
This is a paperwork issue and will not effect your kits. I will keep the group posted on our progress to test first flight and beyond.
So if you are build a E-LSA check your 8130-15 form it should not state ground and flight tested successrull and in in a condition for safe operation. This statement is for Special Light Sport Aircraft ONLY. The E-LSA will NOT have this statement in the certification block.
