Hi, Haven't got to page 34-07, step 2, yet and have bad dreams about cracking the canopy? I did and didn't have a person to back up my drilling through the canopy skirt/canopy/ attach angles, so I did it differently. This way produced clean holes and no cracking: 1. Use a plexiglass drill. I bought mine from W.L.Fuller- high quality and $5 2. Drill when canopy is in the 70 to 80 degree range - may be less likely to crack 3. Prop the aft end of the canopy, attached to canopy frame, up 12" or so. 4. Clamp a 1/8" thick piece of aircraft plywood(or equivalent) to the inside of the attach angle, using "Pony" brand, or equal, spring clamps to hold skirt, canopy, and attach angle tightly together. Position the clamps very close to each side of the hole you are drilling This "backup" step is probably the most important. 5. With canopy skirt clecoed to canopy frame, use the skirt and a standard #27 drill to put a 32nd inch deep centering hole then followup drilling with a #27 Plexiglass drill, using this hole. I wanted the resulting hole to be centered within the skirt's predrilled hole. I didn't see any reason to drill 2 times in each hole(#30 then #27) so, I only drilled a #27 hole. Van's may know something that I don't about this, but the result was what I wanted. I did, however find it quite easy to enlarge the other(already drilled) canopy holes from #30 to #27 by using the plexi drill turning slowly. 3 pictures on Photobucket but haven't figured how to bring them here, yet. Hope this helps, Ken
