The -8 or any of the other planes take about 2200 hours to build where as the -12 can be built in 700 hours +/-.
While the match holes in the -12 are all punched to size and don't need to be deburred, the other kits all require you to match drill the existing holes to size, deburr both sides of each hole, dimple the holes, and then drive the rivers (which can take two people). That can take a good bit of time.
Also, the -8 has a good bit more fiberglass work than the -12. (Wheel pants, wing tips, HS, VS, and rudder tips, and intersection fairings)
Then there is the wiring harness. There really isn't a pre-packaged wiring harness, unless you want a simple VFR steam gauge panel.
The engine install is not a simple package like on the -12, there is a lot of custom work that needs to be done on the Lycoming install.
