A question for those RV-12 builders who have installed a backup airspeed indicator and/or altimeter. What route did you find best for running the static air line from the empennage to the front panel?
Plan to install a backup air speed indicator and most likely an altimeter as well. About to start assembling the fuselage and thought it would be a good idea to map out the route for static air now rather than later.
Thanks in advance for sharing your knowledge.
