Being LSA I'm pretty sure it was never meant for acro.What's the general feeling about the RV-12 doing aerobatics?
I think they'll say NO. I maybe wrong but that's my prediction. I believe they have only tested for stalls.What does Vans say?
18 This aircraft may conduct aerobatic flight in accordance with the provisions of § 91.303. Aerobatics must not be attempted until sufficient flight experience has been gained to establish that the aircraft is satisfactorily controllable. The aircraft may only conduct those aerobatic flight maneuvers addressed in the aircraft's operating instructions and that have been satisfactorily accomplished during flight testing and recorded in the aircraft records. The aircraft may only conduct those aerobatic flight maneuvers that have been satisfactorily accomplished during flight testing and recorded in the aircraft maintenance records by use of the following, or a similarly worded, statement: "I certify that the following aerobatic maneuvers have been test flown, and that the aircraft is controllable throughout the maneuvers' normal range of speeds and is safe for operation. The flight-tested aerobatic maneuvers and speeds are _________ at _________, _________ at _________, __________ at _________, and __________ at _________."
NOTE
Aerobatic flights may be permitted in the assigned test area. The applicant should be advised that aerobatics or violent maneuvers should not be attempted until sufficient flight experience has been gained to establish that the aircraft is satisfactorily controllable. These operating limitations may be modified to include only those aerobatics/maneuvers that have been satisfactorily accomplished and recorded in the aircraft records during the flight test period. These aerobatic maneuvers should be permitted upon leaving the assigned test area. Appropriate limitations identifying the aerobatics/maneuvers and conditions under which they may be performed should be prescribed. The FAA may witness aerobatic maneuvers if deemed necessary.
Through all the internet reading and videos that I have seen of it, it is not meant and designed for aerobatics as per say. I haven't seen the official Vans word on it. I havent seen the G loading figures released, but I doubt is is stressed for Aerobatic category 6G+. If you really want to do Aeros, rather get an Aeros capable machine! RV4,6,7,8 The price is only 'slightly' more, but a lot more work.What's the general feeling about the RV-12 doing aerobatics? What does Vans say? What are the G-limits?
We don't know Officially since the kit for tanks are not released, but I doubt it has flop tubes. No the standard Rotax uses normal float carbs so it is not setup for inverted.Does the ELSA kit include flop tubes? Is the Rotax engine set up for inverted operations?
Sorry can't help you I have only seen videos of normal utility type flying.Those who have flown it - is it suited to this type of sport flying?
i think sonex makes an aerobatic LSA qualified kit. weighs more than the regular one but still makes the 1320...and of course its rated for the g's.
pete
Hi Jeff, I'll give you one opinion, mine...
I was waiting for someone to ask a Question like this...
Yep, like clockwork. It won't be long until 'Can I put an O-320 on an RV-12?' shows up!![]()
Why stop there? Why not an IO-360 or IO-540 or...Yep, like clockwork. It won't be long until 'Can I put an O-320 on an RV-12?' shows up!![]()
What does Vans say? What are the G-limits? Does the ELSA kit include flop tubes? Is the Rotax engine set up for inverted operations?
When I was flying the 12 with Van, I specifically asked Van if the plane was going to be stressed for aerobatics and he said NO. I asked if the plane would be a utility category as far as G limits and he said NO. I asked him about the G limits and he said he did not know what the limits were.
All things considered, I'm sure Bob Hoover would roll a -12 over.![]()
I taught aerobatics in the USAF. Everyone can and will make an error and need more aircraft capability then the initial intent. Doing it in a non-aerobatic aircraft you could very well find yourself without that capability.
Regarding the purpose of this forum, I tend to agree with JD, and feel compelled to speak up in his defense. The purpose of this forum should be to encourage open and honest communication among a group of people with a common interest. If we begin to judge or ridicule the questions asked, then we may find that participation drops off as people feel inhibited about how their questions will be received.
Why is that time after time discussions on acro or buzzing or modifications to RVs have to be either black or white when none are that. Acro could be a lazy 8 with 61 degrees bank, or it could be an inverted spin. Buzzing could be making an upwind pass down the runway at 499' agl, or it could be over someones head down the beach at 175 kts and 10' agl.
While I agree, it is not always easy to determine what is "designed" for aerobatics.I guess my opinion is simple... fly aerobatics in airplanes designed for that and don't fly aerobatics in airplanes where it's not the intent.
That said, it's a worthwhile discussion. That's what forums are for.
This is exactly why I'm very very conservative about responding to ANYTHING. For fear of getting "beat-up" byt the know-it-alls.
Marshall Alexander
