TomVal
Oil filter: What do you use to cut open the filter for contaminant inspection. Will my wife’s electric can opener work?![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
External Boarding Steps: There is an air gap where the leg of the step passes through the fuselage. Shouldn’t there be a seal or gasket closing up that area?
APRS: What has been your antenna location solution. I am also evaluating ADS-B options at this time. I presently have four antennas (xponder, 2 comms, 1 nav), and I am dreading the thought of having to poke more holes in the fuselage.
Wing Hard Points for Jacking: What are folks using? It would be nice if someone like Anti Splat Aero would manufacture a quality hard point.
Regards,
Regards,
