Just over 8'.
This is subject to load----more weight (engine ETC), more spread.
BTW, the 8' is with engine and fuse basically done.
Also, big welcome to VAF Dennis, welcome aboard
I will need to extract the fuselage out this 6 foot "hay loft" door from front to back, or back to front, not side ways. I assume with some thought I could construct a platform upon which to build the fuselage that could be lifted with a fork lift to remove the project from the second floor to the first floor. Does this make sense?
I believe Tim's site has that figure.How long is the fuselage minus the firewall forward and empennage parts?
My project will be built on the second floor of a carriage house. I can extract the fuselage through this "hay loft" door which is 6'wide by 8'tall. I believe I could build a rolling fuselage stand as Bob L has, roll this near the exit of the hay loft door such that a fork lift could get close enough, possibly placing the firewall against the uprights of the forklift, and lift up the fuselage to take it out the hay loft door. Possibly strapping the fuselage down to the forks of the forklift will help keep it stable. The fuselage needs to come out the door lengthwise. I like Bobs mobile stand. I think I could construct it so that the lower portion would have slots built in to eventually accept the forks of the forklift. What do you think?
