Hi Guys 'n Gals. I live in South Africa and have an RV-10 which was built by a friend; I then bought it from his estate.
The problem I found relates to the engine vibration isolators fitted to this engine. They were supplied by Vibration Isolator Products of San Fernando Ca. I have emailed them 4 times, with no reply. So go figure..
The problem I encountered was that the lower forward vibration isolators (not in compression) were clear/away from the motor mount lug/casting. It looks as though the spacer between the vibrator isolators is too long. Considering no one replied at VIP, I then machined the one spacer shorter by .050" and this solved the problem.
Have others had this sort of problem?
Regards, Chalkie.
Regards, Chalkie.
