Please see my question in the attached picture...
RV10Rob Well Known Member Feb 9, 2011 #2 Just flatten the dimple with a squeezer and move on. That hole eventually gets a nutplate and #6 screw (to attach the empennage fairing). -Rob
Phil Well Known Member Feb 10, 2011 #4 Yeah, that hole will need to be flattened because the rear spar of the vertical stab nests into that pocket on the back of the tailcone. I agree with the other suggestions. Put two flush sets in the squeezer and use that to flatten the hole back to its original position. Phil
D drewhottub Active Member Feb 14, 2011 #5 Thank you Phil said: Yeah, that hole will need to be flattened because the rear spar of the vertical stab nests into that pocket on the back of the tailcone. I agree with the other suggestions. Put two flush sets in the squeezer and use that to flatten the hole back to its original position. Phil Click to expand... Gentlemen, thank you very much! Your quick responses were extremely helpful! -Andrew Boyd (the person who originally posted this question)
