Hopefully someone has the answer to this. But what is the best way to remove a damaged side window on an RV-10. I have put the plexiglass and left the edge of the plexiglass that is bonded/adhesive to the fuselage. I can chip away at the plexiglass and get it off, but is there a product or easier way to have the adhesive release the bond?
Thank you...
Thank you...
