Tom Martin
I went to install the roll servo in the right wing of the RV10 and I was not comfortable about the method of attachment for the roll servo "stop". This stop is to make sure that the arm does not move so far as to lock the control system and as such it is an important part. It is held in place by two 4-40 screws that mate with matching taped holes in the servo body. as the "stop" is partially located on the bracket a standard 960 washer is used as a spacer. This leaves only one or two threads securing this important part.
This picture shows the standard setup.
[/URL]
Uploaded with ImageShack.us[/IMG]
This picture is self explanatory. You could get screws that were a bit longer but there are moving parts in the servo that could contact longer screws and at the end of the day they would still be the very small 4-40 size.
[/URL]
I fabricated a bracket that would attach to the unit using the same main mounting bolts. I used a scrap of .063 20-24. The stop is attached to this new bracket with #8 flush head screws and lock nuts.
[/URL]
This was a very simple fix for what I consider a dangerous installation. There are no modifications required to the mount or the servo. There is an added benefit of moving the "stop" further out, relative to the servo arm so that the arm contacts the stop better. I used the same clocking as the previous mounting and it slips right into the servo and will be much easier to install then trying to get those little tiny screws in place. I hope that Tru trak will look at this option as something that should be added to their units. Feel free to copy!
Note: the bolts have not yet been safety wired as per plans and this installation may only apply to the RV10 and not other types.
![img0634e.jpg](/proxy.php?image=http%3A%2F%2F%5BURL%3Dhttp%3A%2F%2Fimg850.imageshack.us%2Fi%2Fimg0634e.jpg%2F%5D%5BIMG%5Dhttp%3A%2F%2Fimg850.imageshack.us%2Fimg850%2F5593%2Fimg0634e.jpg&hash=0602ed91f3180612bfee9379d30eb54d)
![img0640xx.jpg](/proxy.php?image=http%3A%2F%2F%5BURL%3Dhttp%3A%2F%2Fimg405.imageshack.us%2Fi%2Fimg0640xx.jpg%2F%5D%5BIMG%5Dhttp%3A%2F%2Fimg405.imageshack.us%2Fimg405%2F4718%2Fimg0640xx.jpg&hash=e4937ea4d34f45befe6828ac6082dbd1)
![img0643ax.jpg](/proxy.php?image=http%3A%2F%2F%5BURL%3Dhttp%3A%2F%2Fimg202.imageshack.us%2Fi%2Fimg0643ax.jpg%2F%5D%5BIMG%5Dhttp%3A%2F%2Fimg202.imageshack.us%2Fimg202%2F7011%2Fimg0643ax.jpg&hash=396723c33e7d9213adc6d0f4764fa378)
