Royce,
I second the logging into Tim's site for info but I'll help you a little until you do. First the flap leading edge needs to be right up against the rear spar, this is a -3 degree reflex position. Once that is confimed you align the aileron and flap trailing edges, I use a soft jaw clamp to make sure they stay aligned. Next verify the trailing edge of the wing tip is lined up with the trailing edge of the alieron. Now confirm the control stick is vertical. You may also want to check that the trim is indeed full left. If it is the Van's bias spring system you will need to confirm what is full left, center and full right. FWIW since you are not the builder and do not have the repairman certificate, I don't think you can't rig your own flight controls but at least you can check them. Tim's site has a good section on fine tuning the cooling.
