I recently brought home an RV-10 that had a small(ish) firewall forward fire and had sat for 3 years or so post fire. The price was good, and this gives me a path to having a 10 faster than I could build one.
The fire was just barely bad enough to justify redoing everything firewall forward. There were only a few wires that lost insulation, but there was a lot of soot. I'm still replacing all the wiring, hoses, controls etc. The engine is out for a full refresh. I'm doing a full panel refresh at the same time.
I've been studying the forums hard for a couple of weeks trying to get up to speed regarding the issues and decisions that I need to make in this process. The bottom cowling was damaged and I really like the look and performance of the Showplanes cowling, so l have it and a Barret CAI setup ordered. Question 1: I will need a spinner for the Showplanes cowling. I like the look of the polished aluminum Hartzell spinner but the cost seems steep. I have seen mention of places to get this at a discount, but I haven't identified a source. Does anyone have a conact to get the Hartzell at a reasonable cost? What are the best options for a composite spinner?
Question 2: The engine mount and nosegear are the older design. There was some slight heat damage to the powdercoat and it generally needs fresh powdercoating anyway. I understand that there may be a need to swap a tube for clearance with the CAI sump. I have done a visual inspection and I don't see any cracks, but is there a compelling reason to swap to the new mount and nosegear setup from Vans?
Thanks!
Thanks!
